Hi, I want to run a 24v motor with a 12v h-bridge mosfet driver (HIP4081A). I haven't try it in real life but I made the schematic. I want to know before testing it if you can find any error or bad idea in my schematic.
I was successful to run the motor on 12v with the same battery than the driver.
Whether your circuit is good depends on whether your 12 volt power supplies are fully isolated or not. While good ones usually are, if you're going with cheap Chinese models there is no guarantee - and just because the supply carries a sticker proclaiming that it conforms to some standard or UL doesn't mean it's true.
I suggest you test your power supplies to make sure that if you stack them there is no unwanted current flowing.
WhatRoughBeast
  • 60,521
  • 37
  • 97
