Can anyone tell me how difficult, time consuming and expensive is to reverse all layers of a die ? Say a die from a recent model SoC Processor IC found in smartphone devices such as the Qualcomm Snapdragon SoC IC ? Also is it possible to de-cap safely an IC using a houshold kitchen microwave ?
JkT
  • 221
  • If you want to use a Microwave (and to that question: nope) you don't have a Scanning Electron Microscope, I presume? Forget analysing a 22nm structure. let alone a multi layer one. – Asmyldof Aug 25 '15 at 22:47
  • Thanks for the response. Nope I don't have an electron microscope but in this post it says its quite easy to reverse an IC http://electronics.stackexchange.com/questions/13472/is-it-possible-to-reverse-engineer-a-chip-design – JkT Aug 25 '15 at 22:50
    It's possible, but it requires a couple million dollars worth of equipment. It's not "easy" in any sense that could be done at home. – pjc50 Aug 25 '15 at 23:15
  • @VictorMehta Yes, that answer does say it's possible, but those pictures aren't made with a phone camera. Those lines and etches for a post year 2000 SoC are at widest 1micro meter. That's 1/1000th of a milimeter, is 1/25400th of an inch. And that's the widest, never mind the smallest. – Asmyldof Aug 25 '15 at 23:19
    In our company's FA lab, we use a nitric acid fountain to etch open the epoxy package to examine the bare silicon die. (This is for failure analysis of customer returns of our own products, not reverse engineering; but similar principles.) Read the MSDS, this is dangerous stuff to work with: http://www.labchem.com/tools/msds/msds/LC17770.pdf Not suitable for home/hobby use. – MarkU Aug 26 '15 at 01:46
  • There are plenty of resources available via Google in regards to reverse engineering chips. One such site is http://www.bunniestudios.com/ – Dwayne Reid Aug 26 '15 at 05:28
Without super high resolution X-ray machines and a scanning electron microscope you won't be able to reverse engineer a modern chip. The node process used is probably sub 100 nano meter. The post and subsequent article that you quoted is about reverse engineering a very old chip with less then at most tens of thousands of transistors. The Qualcomm Snapdragon is in the millions.
vini_i
  • 7,108
  • 33
  • 52
