i am using an LM317 as a Current Regulator for series LED similar to protecting LEDs From over current ( in time of short circuiting) for my LEDs and Mosfets, similar to this picture:
the problem is that i need bigger voltage source ( up t0 20V) and momre cost fo voltage source and LM317 IC, because of dropping voltage on the LM317 ( in range of 4.5v to 5.5V) so if i found another eleman ( similar to fuse or ...) for protecting LEDs AND MOSFETs at the time of over currenting. so is there any alternative (for protecting LED ANd MOSFETS) and is it OK i use one fuse instead of current regulator ( which one is first to burning : MOSFET or Fuse). Thanks a lot.
