Here's a Python module that uses a different notation for boolean expressions. It is the notation used in http://en.wikipedia.org/wiki/Canonical_form_%28Boolean_algebra%29 where there is an implicit AND between adjacent variables, + means OR, and a trailing single quote ' inverts whatever it comes after. So, (A v B ) + ~ C in Wouter's example would be written as (a + b)c'
To print the truth table of the expression, call the module as:
>>> printtruth("(a+b)c'")
a b c F
0 0 0 0
0 0 1 0
0 1 0 1
0 1 1 0
1 0 0 1
1 0 1 0
1 1 0 1
1 1 1 0
The module itself:
def parsebool(s):
tokens = list()
allvars = set()
paridx = list()
lastpar = None
for i, char in enumerate(s):
if char == "'":
if len(tokens) == 0:
raise ValueError("cannot negate empty expression")
elif tokens[-1] == ")":
tokens.insert(lastpar, "not")
else:
tokens.insert(-1, "not")
elif char == "(":
if tokens and not (tokens[-1] in ("or", "and", "(")):
# implicit and
tokens.append("and")
paridx.append(len(tokens))
tokens.append("(")
elif char == ")":
tokens.append(")")
lastpar = paridx.pop()
elif char.islower() or char == '0' or char == '1':
# implicit and
if char.islower():
allvars.add(char)
tokens.append(char)
elif char == "+":
tokens.append("or")
elif char == "*":
elif char in " \t\n":
pass
else:
raise ValueError("invalid character in input: \"%s\"", char)
return tokens, allvars
def boolfunc(s, name="F"):
tokens, allvars = parsebool(s)
allvars = list(sorted(allvars))
lambdastr = "lambda %s: %s" % (','.join(allvars), ' '.join(tokens))
F = eval(lambdastr, {'__builtins__':None}, {})
F.func_doc = 'Boolean function %s(%s) = %s' % (name, ', '.join(allvars), s)
F.func_name = name
return F
def printtruth(F):
if not callable(F):
F = boolfunc(F)
varnames = F.func_code.co_varnames
Fname = F.func_name
allnames = varnames + (Fname,)
rowfmt = " ".join("%% %ds" % len(v) for v in allnames)
print " ".join(allnames)
for args in itertools.product((0,1), repeat=len(varnames)):
try:
result = str(int(F(*args)))
except Exception:
result = "E"
print rowfmt % (args + (result,))
def printcompare(F, G):
if not callable(F):
F = boolfunc(F)
if not callable(G):
G = boolfunc(G)
Fvarnames = F.func_code.co_varnames
Fname = F.func_name
Gvarnames = G.func_code.co_varnames
Gname = G.func_name
varnames = tuple(sorted(frozenset(Fvarnames).union(Gvarnames)))
allnames = varnames + (Fname, Gname, "=")
allequals = True
argdict = dict(zip(varnames, args))
Fargs = [argdict[n] for n in Fvarnames]
Gargs = [argdict[n] for n in Gvarnames]
try:
Fresult = str(int(F(*Fargs)))
except Exception:
Fresult = "E"
try:
Gresult = str(int(G(*Gargs)))
except Exception:
Gresult = "E"
equals = Fresult == Gresult
allequals = allequals and equals
print rowfmt % (args + (Fresult,Gresult,equals))
if allequals:
print "functions are equivalent"
else:
print "functions are NOT EQUIVALENT"
