What would be a cost-effective means to store power obtained from solar and wind generators for home use?
Batteries are very expensive, and I'm looking for alternatives; e.g.: a (hare-brained?) idea is to use series of elevated water tanks that get's filled when surplus power is available, and then used to gravity-drive a generator in dark&windless times. What other means are available?
slashmais
  • 415
  • We need more details to give you on target solutions. What defines a correct answer to this question? We need to know what level of power you are talking about. How long it needs to be stored for(an evening, a week, a month?). – Kortuk Aug 18 '11 at 10:31
    Also, on the cost note, think about how long it takes to build water towers and maintain the motors and towers. – Kortuk Aug 18 '11 at 10:31
  • Related question http://electronics.stackexchange.com/questions/4323/alternative-energy-storage – mjh2007 Aug 18 '11 at 16:54
Energy storage is big business...
There are many ways to store energy.
Your idea of the water tanks is a reasonable one, and not that hare brained. It's exactly what a number of hydro-electric plants do. They pump water to a high reservoir during slack times, and then use the descending water to generate power during high demand times.
Other ways are, as you say, batteries (expensive) or big capacitors (even more expensive).
If you have the space then a flywheel is also a possibility.
You crank up the speed of a huge heavy wheel when you have the power, then use its momentum to generate power at other times. This is sometimes used for big UPS systems for server farms. I know that, for instance, HSBC have a massive one underground to act as one (of many) of their UPS systems to protect the bank computers.
This takes a huge amount of space, and you need good bearings or you'll lose all your power through friction. A vacuum is also handy to reduce air resistance.
Other mechanical ways could be to use clockwork. A motor winds a spring up during times of excess power, and then it unwinds generating power when you need it. Or you could use elastic, or springs, to store the energy - stretch them out using your excess power, then let them collapse back while generating power.
There are many many ways - it all depends on how much space you have and how much complexity you want to get in to.
Majenko
  • 56,223
  • 105
  • 189
  • The less complex a solution, the better. Fewer things to go wrong & hopefully easy to fix if when. – slashmais Aug 18 '11 at 10:06
    Then you're really looking at batteries - expensive as they are. Much simpler and less to go wrong. – Majenko Aug 18 '11 at 10:06
