How much voltage is required for the earphones by which we listen voice and songs ? Please help with the calculations if possible??If we keep our earphones plugged with our mobile phones,do the battery gets discharged faster?
Asked
Active
Viewed 273 times
-1
The meaningful part of this question is a duplicate. Obviously any sane design for a battery powered audio device will not present a DC bias across a speaker (indeed, that is generally avoided regardless of the power source) so there should be next to no power consumption when not actually producing audio. – Chris Stratton Jul 05 '15 at 15:45
You can refer to this Article for calculation part under sensitivity section. Regarding the discharge part I don't think plugging on would lead to higher battery drain because once earphone is plugged it bypasses the inbuilt speaker which consumes a lot more power than earphones. I hope the answer is right.thanx
Most phones today do not have the earphone bypass the speaker, rather a second audio path becomes available but software selects between them (rings still go to the speaker typically), and when not producing audio neither is active. – Chris Stratton Jul 05 '15 at 15:46
