For large appliances I usually see a 3-prong plug while smaller electronics will use a 2 prong wall wart with a DC barrel. When designing electronics, how do you know if you'll need an earth ground? Are the two prong designs inherently more dangerous?
Asked
Active
Viewed 235 times
The regulations are described here: https://en.wikipedia.org/wiki/Appliance_classes . Actual implementation varies by country - all UK sockets have 3 pins for example.
Small appliances can use low-current low-voltage DC. All the safety isolation is in the wall wart; it's not possible for the appliance itself to fail in a way that gives the user an electric shock.
Larger appliances either have a power supply built in or use mains directly (drills, white goods, lamps, etc). These must either be double-insulated or have an earth ground.
pjc50
- 46,725
- 4
- 65
- 126
