I'm wiring 5V from a power supply directly to a micro USB cable. I'm only using the +5V and GND connectors, and leaving Data+ and Data-. While I only plan to use the cable for power, do I need to do anything with that D+ and D- cables, or can I leave them disconnected from both ends?
UPDATE I should clarify that the USB cable is connected to a Raspberry Pi, not a basic circuit.
Melllvar
  • 147
You can leave them open.
Think about it this way - if nothing is plugged into the USB port they are essentially not connected to anything anyway.
MindFlayer
  • 98
