I am going to have a something thats runs on 120vac pulling 1-2amps is there a chart or something for choosing the right gauge of wire?
The wire will run from an inverter in the front of my car(by the battery) to the back (near the taillights).
I need the smallest diameter wire possible.
AKR
  • 2,293
  • 22
  • 35
AndrewFerrara
  • 337
The maximum current a wire can carry depends on several factor:
  1. wire diameter, obviously (Kortuk may take exception on me using the word obvious again, but this time it really is; anyone older than 10 will understand that thinner wires will allow less current through them)
  2. wire material. Often copper, but in some applications where weight is paramount aluminium may be used. Think overhead high-voltage power lines.
  3. insulation. The energy dissipated in the wire will cause a temperature rise, but the heat will also be given to the environment. The type of insulation determines the amount of thermal isolation. It also determines the maximum temperature allowable. Think melting of the insulation. edit: insulation will also determine maximum voltage. The insulation may breakdown when too thin in combination with a high dielectrical constant.
This document gives the maximum current for copper wire as a function of diameter and temperature rise in free air at 30°C ambient temperature.
stevenvh
  • 145,832
  • 457
  • 668
There are charts that give properties for different gauges of wires. However, you haven't said what your criterion is so there is no way to give a single answer.
One spec might be how much voltage you are willing to let the wire drop. At your 2A current you can compute a maximum resistance from that. With the Ω/foot from a chart, you can compute the maximum length of each guage of wire your system can tolerate.
Or, your criterion might be maximum temperature rise of the wire. There are charts for temperature rise as a function of current for various wires.
For house wiring there are legal requirements too. These are usually based on temperature rise. Each gauge is specified for the maximum fuse or circuit breaker that must be on that circuit.
Olin Lathrop
  • 313,258
  • 36
  • 434
  • 925
  • The wire will run from an inverter in the front of my car(by the battery) to the back (near the taillights). – AndrewFerrara Jul 17 '11 at 11:57
  • It may not be a good idea to put an inverter in the engine compartment. Automotive engine electronics has a higher temperature requirement (150 C max) than consumer electronics (70 C max). Strictly looking at your current requirements, 18 AWG could do just fine, but most 18 AWG wire won't be rated for that voltage. In a house, you'd be required to use 14/2 wire (14 AWG, 2 conductors plus ground), but I have no idea if THHN is rated for auto temperatures. – Mike DeSimone Jul 17 '11 at 12:09
As Olin notes, if this is for house wiring it will need to meet regulatory limits.
If safety is a concern you may be concerned with eg temperature rise.
"Smallest diameter possible" may be to fit in a duct etc - you need to say WHY for this to be able to be answered well.
Here is a table that will both help and confuse. Note that at lower current levels there are two standards that vary widely. See also the note re contacting your local electrician re legality.
http://www.powerstream.com/Wire_Size.htm
All that said, if smallest diameter is really your aim, then something like 26 gauge AWG is liable to be "fairly safe".
See also
http://www.interfacebus.com/Copper_Wire_AWG_SIze.html
which only gives the very conservative rating and suggests you'd want about 18 gauge (likely to be unnecessary but YMMV).
As a general guide: http://en.wikipedia.org/wiki/Standard_wire_gauge
And http://www.bulkwire.com/wiregauge.asp
Russell McMahon
  • 150,303
  • 18
  • 213
  • 391
