On a schematic I have, some resistors read as R16, 0.025R, 3W. Some read as R60, 33R. I guessed that R16 or R60 are the labels, and 3W is the power. But what does 0.025R or 30R mean? Google search did not help much. Thanks.
Asked
Active
Viewed 2,555 times
Related: http://electronics.stackexchange.com/questions/90699/wire-wound-inductors-naming – Ignacio Vazquez-Abrams Apr 22 '15 at 16:15
1So many possible duplicates: http://electronics.stackexchange.com/questions/246920/what-is-a-100r-resistor – Always Confused Aug 09 '16 at 10:15
http://electronics.stackexchange.com/questions/45272/resistor-value-labeling-what-does-the-second-number-refer-to http://electronics.stackexchange.com/questions/107698/what-does-5k1-in-the-given-schematic-mean http://electronics.stackexchange.com/questions/28053/what-does-3v3-or-1v8-mean – Always Confused Aug 09 '16 at 10:17
In this context "R" means \$\Omega\$.
It really just substitutes for the decimal point and tells you the multiplier. You'll also see inductors marked 1R0 for 1.0\$\mu\$H, and resistances given as 4K7 or 10K0 for 4700\$\Omega\$ and 10,000 \$\Omega\$.
So the resistor with ID R16 is a 0.025 Ohm resistor and the resistor with ID R60 is a 33 Ohm resistor.
Spehro Pefhany
- 397,265
- 22
- 337
- 893
@Chu If it starts with "R" in this context, that is the reference designator. This is generally why the value of the resistors don't contain "R"s. – ACD Apr 22 '15 at 15:57
@EMFields Yes, thanks, some weird editing there- no doubt my fault. – Spehro Pefhany Apr 22 '15 at 17:55
Different manufacturers = different methods. The K, M or R can be the decimal point. 33K = 33KΩ, 4K7 = 4.7kΩ. Surface mount 472 = 4.7kΩ or 4701 = 4.7kΩ at a higher precision. – StainlessSteelRat Apr 22 '15 at 18:05
