I found a CNA1011K photocoupler laying around and I wish to try it out. Could someone explain what the parameters from the datasheet mean and how to use them for particular circuit parameters?
LED maximum current If: 50mA - that's understood. How about the voltage across it? Standard LEDs have nominal voltage and current ratings, but not this one.
Reverse voltage and current: why should I care about them?
Forward voltage: @ If= 50mA is 1.2V. How do I ensure a 50mA current? If I use a 50Ohm resistor, as in the circuit diagram, the current will be 24mA, right?
Is it better to alter the light intensity by increasing the voltage or the current through the LED?
How do I know what base current range I can generate with LED? How to choose the RL value based on an arbitrary Vcc voltage, what is the Vcc range?
