I'm trying to select a 32kHz crystal and appropriate load capacitors for Atmega48A MCU.
Atmega48A specifies different capacitances for Xtal1 and Xtal2 pins:
18pF for Xtal1 8pF for Xtal2
The datasheet says: "The capacitance (Ce+Ci) needed at each TOSC pin can be calculated by using:C = 2 * CL – Cs" Where CL is load capacitance specified for the crystal and Cs is stray capacitance.
Can I assume that each pin has (18+8)/2=13pF of capacitance? Can I select a 8pF crystal and use it without external load caps assuming ~3pF of stray capacitance?
