One of the answers to this question advised I used a reset signal for my fpga design. I agree, it's good advice and I'm adding it. Is there any way for me to ensure that this signal gets asserted on startup though withoug adding additional hardware? This is on a spartan-3an evaluation board.... I can't find anything in the documentation anywhere
The easiest way is a simple RC circuit, but if your board does not have one, you will have to add it. It is very very easy to add though, just a resistor and a capacitor. – Kortuk May 03 '11 at 11:18
With an FPGA you can make use of the fact that your flipflops will initialise to a known state and create an internal synchronous reset signal which you can "and" with the external one.
When using an external reset, make sure that you synchronise it to the internal clock (with a different synchroniser for each clock if you have more than one) otherwise you may find that your logic comes out of reset in weird ways. This is because the signal will have different delays to different parts of your circuit and if the reset button is released just before a clock edge, some parts of the FPGA will see it (as the reset signal made it to them before the clock signal) and other parts will see it one clock cycle later (as the reset was slightly delayed and therefore missed the clock edge).
- 8,499
- 1
- 23
- 44
2Also this white paper from Xilinx can be useful: http://www.xilinx.com/support/documentation/white_papers/wp272.pdf – Code Painters May 03 '11 at 16:20
