I purchased a Pyle 9" TFT monitor for use in an automobile with back-up camera. The wiring is designed to connect directly into the car's harness. I have no info on the electrical requirements other than, of course, 12V from the car.
I plan to use this monitor inside to make my nephew a headboard with digital photo/video/netflix frame. I've wired some indoor 12V lighting before, but probably just got lucky. I want to know if a similar power supply will work here? I'm looking at a DC 12V 2A Power Supply Adapter for 110V-240V AC 50/60hZ (whatever that means?). Does that sound like that will work? Should I get the 3A version to be sure since I read on this website the whole "amps are like apples" analogy?
Adam Head
  • 1,436
  • 17
  • 27
  • Is it this one? The manual for that one says 6W. – Ignacio Vazquez-Abrams Oct 15 '14 at 15:43
  • Not so much a duplicate as that the manufacturer doesn't make it easy to determine the power consumption. The online manuals don't mention it, and I only found it because one online shop that sells them put it in their description. – JRE Oct 15 '14 at 15:45
  • @JRE: It's definitely in the manual for both models. – Ignacio Vazquez-Abrams Oct 15 '14 at 15:46
  • @Ignacio Vazquez-Abrams You are right, I found it after taking a second look in the manual. I had started out looking for current and completely missed the power entry in the table. – JRE Oct 15 '14 at 15:48
Assuming a typo and you meant the Pyle PLHR78W, I find that it consumes 8Watts, which would be 0.67 Amperes at 12Volts. Your 2Amp, 12Volt power supply should be fine.
I can't find PLHRQD8W anywhere, which is why I assume your voice type software mangled it. Even if not, the power consumption should be comparable - the power consumption seems to be coded into the model number, and both say 8W.
JRE
  • 71,321
  • 107
  • 188
