I'm a Microchip guy, but I'm helping a customer out with an Atmel project using the ATmega88PA project they inherited from another division. I'm using AVR Studio 5 and I would like to compile the fuse selections into the source code and eventually hex file. How do I do this?
Asked
Active
Viewed 2,483 times
You can't, they have to be set in AVR Studio.
If you use the AVRdude utility, programming and fuse settings can be automated with makefiles.
Leon Heller
- 38,983
- 2
- 62
- 96
So, how do you setup production for these chips? Is there another fuse setup file I have to generate? – kenny Apr 06 '11 at 18:32
1Either save the fuse options as command line values or in a file as is described here: http://electrons.psychogenic.com/modules/arms/art/14/AVRFusesHOWTOGuide.php and also fuse calculator here: http://www.engbedded.com/fusecalc/ – AngryEE Apr 07 '11 at 00:08
@kenny That is a good question (maybe you should ask it). We use a command line programmer and call it with the correct fuse bit settings from scripts (each product gets a new script) but we are a rather small shop. What do the big guys use for AVRs? – jpc Apr 07 '11 at 00:18
@AngryEE and @jpc, thanks. I didn't realize those command line tools existed. And I see that AVRDude is a console application now. – kenny Apr 07 '11 at 10:53
jpc: I would think that large companies use a gang programmer that can load the fuse configuration from a file, or get their chips supplied pre-programmed. – Leon Heller Apr 07 '11 at 11:10
1Gang programmer, ha! He'll set a fuse in yo chip. – AngryEE Apr 07 '11 at 12:05
