Is it possible to insert a converter between regular 10A 240V mains supply that would be capable of running a tool rated at 16A, 3500W?
Obviously, the tool won't run to it's full capacity but could it work for a portion of its capacity?
Ricardo
  • 6,164
  • 20
  • 53
  • 89
A 10 amp 240V supply can only deliver 2400 watts. If I assume the tool is rated for 240V and draws 16 amp, it would need a maximum of 3840 watts. The rating of 3500W may be because the tool does not have a power factor of 1. In any case, a converter can only change one voltage into another (or change AC to DC); it cannot increase the wattage capacity of your main supply. Depending on the type of tool, you could damage it if the proper power is not applied. There certainly is a good chance you will blow the main supply fuse or circuit breaker.
Barry
  • 15,967
  • 26
  • 28
