If most use some sort of li-ion battery, and those batteries like to be charged in CCCV format how can my phone charge just fine at 5V, 500mA or 5V, 1A or 5V, 1.2A just fine (actual current delivered, not power supply capabilities)? It seems the current is not constant. If I made a 5V, 1A battery charger it is recommended to not use a 5V, 0.5A supply since the charger was designed for 1A.
Do phones just have really complicated charging circuitry that differs from the standard li-ion charging ICs? Everyone can either charge their phone with USB at 500mA or use a wall adaptor for a faster rate.
ACD
  • 2,383
  • 27
  • How do you know what the ACTUAl current is? |
  • LiIon usually charges at a max of C (eg 1000 mA for a 1000mAh battery) BUT some manufacturers allow more - maybe 1.5C or 2C - and a few specify 0.5C. In CC mode it is usually OK to charge at less than or equal to the battery's maximum. In CV mode the battery sets the current.
  • – Russell McMahon Jul 04 '14 at 14:57
  • I have an ammeter in series with the charging cable output. I was more curious on how they did it, and I think one user said below that the charging load can be variable impedance to get the most juice allowed, up to a limit of course. – ACD Jul 07 '14 at 13:51
