I need to use a resettable fuse in my design and I'm using something like this:
Can strap type fuses be used on PCB and how can they be mounted on PCB?
The flippant answer is sure, you can mount them on a PCB (or glue them to a marble bust of Julius Caesar) if you like.. but (there's almost always a 'but') they might not do what you want.
The PTC fuses are temperature and heat-loss sensitive. That's an advantage in a battery protection scheme (they "provide both over-current and over-temperature protection"), however by heat sinking the ends to a PCB you are going to radically increase the hold and break currents if the PCB itself is not getting hot.
SMT poly fuses are less straightforward to deal with than through-hole types because of the extra major variable (heat loss) and I'll hazard a guess that this would be much worse.
