Per the title, what physical or construction parameters determine the frequency range of a current transformer? I happen to be looking at these two from mouser, but I'm sure the question is generic enough to apply to a large number of these things... What causes there to be a thousand-fold different in the minimum frequency?
Also, what happens if you attempt to measure a frequency well outside the rated range? For example, if you tried to measure a 50-60Hz residential power waveform with one of these KHz-range devices?
CT #1 : ICE CT08-1200 - listed as 40Hz - 200KHz
CT #2 : Murata 56200C - listed as 20KHz - 200KHz
JYelton
  • 34,119
  • 33
  • 145
  • 265
ljwobker
  • 295
The lower frequency limit is defined by how many volt-seconds the core can handle without saturating out. Generally, the smaller the core, the higher the minimum frequency, since a higher frequency means smaller on-time and lower volt-seconds for the transformer to deal with.
(Most CTs use ferrite cores, so if there isn't a specified \$ B_{max} \$ you can try 0.22T and figure out what volt-second product you can achieve with your specified burden resistor.)
Adam Lawrence
  • 33,161
  • 59
  • 110
