My virtualbox 5.0 use to work on kernel 4.8.13 and it was in my list of kernels to choose from.
Apparently automatic download and updates removed 4.8.13 and installed the latest kernel available 4.13.x without my knowledge.
Now, virtualbox crashes 100% of the time every time I boot one of the virtual machines. The whole host operating system (Ubuntu) FREEZES COMPLETELY. The only way is to reboot my system (power cycling).
So, I thought maybe I can install 4.8.13 and get virtualbox working again, but I DO NOT see 4.8.13 in the list of kernel images in the repository. And I thought maybe different version of 4.8.X will work. None of the old kernels I have tried so far worked to fix my problem at all. So, what am I doing wrong? What are my next steps in solving this issue?
Zanna
  • 72,312
ThN
  • 223
I think you are using old 5.0 version. Virtual box have released version 5.2.6 with fixes for new Linux kernel version like 4.13.
Kindly consider to manually download and install the same:
https://www.virtualbox.org/wiki/Linux_Downloads
You can refer the changelog of 5.1 and 5.2 from below link:-
https://www.virtualbox.org/wiki/Changelog-5.1
Aravind
  • 943
Reboot to an older working version of the kernel by holding down the shift key during boot up. Then update the grub boot loader to default to the working older kernel. Then upgrade Virtualbox host and guest software. That at least gets you up and working again.
That's what I did. Note that I do not have this problem on different laptop hardware using the same Virtualbox host, guest additions, and Ubuntu. The other main difference between my laptops is that one runs Win7 and the other Win10 so there are other factors involved.
