I started using ocamlfuse to access google drive with Nautilus and it was functioning perfectly fine. The thing is, at some point I used, by accident, the sudo command, I'm not shure if it was to run ocamlfuse:
sudo google-drive-ocamlfuse
Or if I used it when mounting the folder
sudo google-drive-ocamlfuse ~/googledrive
After that, I can only mount the googledrive folder with the sudo command, and if I run
I get this:
"Error: Sqlite3 error: READONLY"
Accessing just by using the sudo command gives me trouble when trying to open multiple documents with Libreoffice and some other applications at the same time.
Run:
sudo chown -R your-username.your-username ~/.gdfuse
This will change the permissions of ~/.gdfuse/default/cache/cache.db back to your user's and then you can perform the command.
At the end I solved this by just removing the package using purge and autoremove. I also erased the .gdfuse folder in home so I could do a clean installation. The problem was solved doing this, in case someone wants to know.
