10
There are similar messages ("Ubuntu repository does not have a Release file" ... but none works for me).
I try to update a system (apt-get update), but I got some errors.
Concretely (main error): [CODE] E:The repository 'http://archive.ubuntu.com/ubuntu yakkety Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://archive.ubuntu.com/ubuntu yakkety-updates Release' does not have a Release file., W:Updating from such a repository can't be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., E:The repository 'http://archive.ubuntu.com/ubuntu yakkety-security Release' does not have a Release file. [/CODE]
My Ubuntu version: Description: Ubuntu 16.10 Codename: yakkety
I tried a lot of solutions found in different threads and different sources, such as : sudo apt-get autoclean sudo apt-get clean sudo apt-get update
I disabled all PPA's from "Other software" of "Software and Updates" (just in case..).
And also, I commented a pair of lines of sources.list file (just to try):
deb http://archive.ubuntu.com/ubuntu yakkety-backports main universe restricted multiverse
deb http://archive.canonical.com/ubuntu yakkety partner
... but the main error remains (see "main error" on top) ...
When I try to : sudo apt-get update
I got this :
Ign:79 http://archive.ubuntu.com/ubuntu yakkety-security/universe amd64     Packages
Ign:80 http://archive.ubuntu.com/ubuntu yakkety-security/universe i386 Packages
Ign:81 http://archive.ubuntu.com/ubuntu yakkety-security/universe all     Packages
Reading package lists... Done
W: The repository 'http://archive.ubuntu.com/ubuntu yakkety Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://archive.ubuntu.com/ubuntu yakkety-updates Release' does not have a Release file.
W: The repository 'http://archive.ubuntu.com/ubuntu yakkety-security Release' does not have a Release file.
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/yakkety/main/binary-i386/Packages  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/yakkety-updates/main/binary-i386/Packages  404  Not Found [IP: 91.189.88.149 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/yakkety-security/main/binary-amd64/Packages  404  Not Found [IP: 91.189.88.149 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Any ideas? Thanks in advance!
Mandor
  • 129
Ubuntu 16.10 is EOL since July 20, 2017.
Change http://archive to http://old-releases in /etc/apt/sources.list file, and run
sudo apt update && sudo apt upgrade
again.
And then update to a supported version.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Soren A
  • 7,191
