I have two drives on my machine, both are internal. However, the second drive keeps showing up as external:
- There is no trash facility on that drive. Files are deleted right away.
- In all the file managers there is the 'Dismount' option, which then fails if i try to do that (since the drive's partition is mounted via fstab).
How can i explain to Xubuntu that the drive is actually internal, so that those things will get fixed?
Here's the line in /etc/fstab:
/dev/mapper/largevg-work /home/volodya/work ext4 errors=remount-ro 0 2
and also
$ udisksctl dump |grep '^[^ ]\|Remova'
/org/freedesktop/UDisks2/drives/MATSHITA_DVD_RAM_UJ8E1_SZD5L67522:
MediaRemovable: true
Removable: true
/org/freedesktop/UDisks2/drives/Multiple_Card__Reader_058F63666435:
Removable: true
/org/freedesktop/UDisks2/drives/ST2000LM015_2E8174_ZDZ09HM4:
MediaRemovable: false
Removable: false
/org/freedesktop/UDisks2/drives/WDC_WDS250G1B0A_00H9H0_172703800034:
Removable: false
My 'large' drive is showing false, as you can see. But still...
