I tried install the nvdia driver for ubuntu 17.10, but it was a failure the display was totally black. So I purged the Nvidia drivers and returned back to generic display driver but unfortunately it was not completely reverted back, which causing the following issues
  1. Never resume back from suspend mode
  2. Display resolution gone back to 1280x800
  3. No brightness control
  4. No night mode
  5. Gama error. etc... My display card is 02:00.0 VGA compatible controller [0300]: NVIDIA Corporation C79 [GeForce 9400M] [10de:0863] (rev b1) The xrandr gives the following error
    xrandr: Failed to get size of gamma for output default Screen 0: minimum 1280 x 800, current 1280 x 800, maximum 1280 x 800 default connected primary 1280x800+0+0 0mm x 0mm 1280x800 76.00* Lightdm service status is
    ● lightdm.service - Light Display Manager Loaded: loaded (/lib/systemd/system/lightdm.service; enabled; vendor preset: Active: active (running) since Mon 2018-01-22 18:44:15 IST; 24min ago Docs: man:lightdm(1) Process: 14037 ExecStartPre=/bin/sh -c [ "$(basename $(cat /etc/X11/default-di Main PID: 14048 (lightdm) Tasks: 7 (limit: 4915) Memory: 33.4M CPU: 2min 56.014s CGroup: /system.slice/lightdm.service ├─14048 /usr/sbin/lightdm └─14069 /usr/lib/xorg/Xorg -core :0 -seat seat0 -auth /var/run/lightd
Jan 22 18:44:16 shameerariff-MacBook lightdm[14083]: PAM unable to dlopen(pam_kw Jan 22 18:44:16 shameerariff-MacBook lightdm[14083]: PAM adding faulty module: p Jan 22 18:44:16 shameerariff-MacBook lightdm[14083]: pam_unix(lightdm-greeter:se Jan 22 18:44:20 shameerariff-MacBook lightdm[14148]: PAM unable to dlopen(pam_kw Jan 22 18:44:20 shameerariff-MacBook lightdm[14148]: PAM adding faulty module: p Jan 22 18:44:20 shameerariff-MacBook lightdm[14148]: PAM unable to dlopen(pam_kw Jan 22 18:44:20 shameerariff-MacBook lightdm[14148]: PAM adding faulty module: p Jan 22 18:44:20 shameerariff-MacBook lightdm[14148]: pam_succeed_if(lightdm:auth Jan 22 18:44:58 shameerariff-MacBook lightdm[14048]: g_object_unref: assertion ' Jan 22 18:44:58 shameerariff-MacBook lightdm[14148]: pam_unix(lightdm:session):
It seems weired to me. I tried restoring using the Wiki Ubuntu but still all my efforts are failed.
