I tried Ubuntu Tweak and dconf-editor but nothing seemed to help. Perhaps if there is an extension for the same, please share if you happen to know this or any other workaround.
Cinnamon Settings -> Window -> Left Sided Title Bar buttons.
You might have to restart cinnamon to see the changes;
here are some ways to do that:
cinnamon --replace &(No need for gconf-editor!!!)
I am guessing it has retained the same gconf settings as gnome-shell since it is just a fork of gnome-shell.
So, you can change the window control buttons layout using gconf-editor
After installing it, press Alt+F2 and enter gconf-editor.
Then, move to Desktop -> gnome -> shell -> windows, and double click on the entry and enter these for button_layout: close,minimize,maximize:.
All that matters is the position of the :.
The other answers didn't work for me in 12.10, so here is how I did it.
There are actually two ways of doing this.
You can also use dconf-editor. First install dconf using
sudo apt-get install dconf-tools
Open dconf-editor and navigate to:
org --> cinnamon --> overrides
Rearrange the value of button-layout from:
:minimize,maximize,close
to
This will move the title buttons from the right side to the left in Cinnamon 1.6.7 and Ubuntu 12.10.
It's in each theme itself. For instance go to usr/themes/Ambiance open the document Ambiance as administrator. At the bottom of the document you'll see this ButtonLayout=close,minimize,maximize:
move the colon to the front of close like this ButtonLayout=:close,minimize,maximize
this one still works.
press alt+f2, go to Apps-metacity-general, edit the "button layout" into this "close,minimize,maximize:"
it will change right away
