I have the following lines in a file:
Modified folders: html/project1/old/dev/vendor/symfony/yaml/Tests/bla.yml
Modified folders: html/port5/.DS_Store
Modified folders: html/trap/dev8/.DS_Store
Modified folders: html/bla3/test/appl/.DS_Store
Modified folders: html/bla4/pro1/app/bla/Api2.php
Modified folders: html/bla10/dev/appl/language/.DS_Store
Modified folders: html/bla11/dev/appl/language/abc.txt
This is basically output of rsync. I would like to list all the lines of the file up to 3 directory places, like
Can anyone please provide me any command or shell script to do the same?
john deo
  • 77
Maybe like this:
$ sed -r 's|/[^/]*$||' file | sed -r 's|([^/]*/?[^/]*/?[^/]*).*|\1|'
Or you can do the second part with cut:
sed -r 's|/[^/]*$||' file | cut -d '/' -f 1,2,3
Notes
  • -r use ERE
  • s|old|new| replace old with new
  • [^/]* any number of characters that are not /
  • $ end of line
  • /? zero or one /
  • (pattern) save pattern to reference later with \1
  • .* any number of any characters
  • | (unquoted) shell pipe - passes output of left hand side command to right hand side command
  • cut -d '/' use / as delimiter
  • -f 1,2,3 print the first three fields
Zanna
  • 72,312
The following script will (almost) do as you ask.
#!/usr/bin/env perl
use strict; use warnings;
while(<DATA>) { s!^(Modified\s+folders:\s+)((?:[^/]+/){1,3}).*?$!$1$2!; print; }
DATA Modified folders: html/project1/old/dev/vendor/symfony/yaml/Tests/bla.yml Modified folders: html/port5/.DS_Store Modified folders: html/trap/dev8/.DS_Store Modified folders: html/bla3/test/appl/.DS_Store Modified folders: html/bla4/pro1/app/bla/Api2.php Modified folders: html/bla10/dev/appl/language/.DS_Store Modified folders: html/bla11/dev/appl/language/abc.txt
It reads every input line, picks some values from it (my means of a regex), replaces the line with the picked values, and finally prints the now modified line (to STDOUT).
Output
If we write the regex in one single line:
then it looks a bit scary but it is actually quite simple. The basic operator is the substitution operator s/// from Perl.
s/foo/bar/;
will replace every occurence of foo with bar. s allows us to change the delimiter from / to something different. I used a ! here, so we could also write
s!foo!bar!;
The ! does not mean not it's just an arbitrary character here. sLfooLbarL; would work as well. We do that because if we use the standard / we would need to escape the / within the parameters (which is then known as toothpick syntax). Consider we want to replace the path /old/path with /new/path. Now compare:
s/\/old\/path/\/new\/path/; # escaping of / needed
s!/old/path!/new/path!;     # no escaping of / needed (but of ! if we had one in the text)
We can also apply the x modifier to the s///. It allows for arbitrary whitespace (even newlines and comments) in the pattern (the left hand side) to improve readablity. Now the loop can be written as:
while(<DATA>) {
    s!^                         # match beginning of line
      (Modified\s+folders:\s+)  # the word "Modified", followed by 1 ore more
                                # whitespace \s+,
                                # the literal "folders:", also followed by 1 or
                                # more whitespace.
                                # We capture that match in $1 (that's why we have
                                # parens around it).
      (                         # begin of 2nd capture group (in $2)
        (?:                     #   begin a group that is NOT captured (because of the "?:"
         [^/]+/                 #   one or more characters that are not a slash followed by a slash
        )                       #   end of group
        {1,3}                   #   this group should appear one to three times
      )                         # close capture group $2, i.e. remember the 1-3x slash thing
      .*?$                      # followed by arbitrary characters up to the end of line
     !$1$2!x;                   # Replace the line with the two found captures $1 and $2, i.e.
                                # with the text "Modified folders:" and the 1-3x slash thing.
    print;
The complete "script" can also be written as a one-liner:
perl -pe 's!^(Modified\s+folders:\s+)((?:[^/]+/){1,3}).*?$!$1$2!x;' file
Update
I just realized that the Modified folders: string can be seen as a component of the path as well. So the pattern can be simplified to
perl -pe 's!^((?:[^/]+/){1,3}).*?$!$1!;' file
PerlDuck
  • 13,885
grep -oP '^.*?(/.*?){0,2}(?=/)'
a brief explanation of the dark regexp used:
  • ^... i the beginning of the line
  • .*? a seq. of chars (but just the necessary amount) to match the pre-path
  • /.*?){0,2} 0, 1 or 2 directories
  • (?=/) look ahead expression -- followed by a / that is not included
