I have tried looking up every possible Ubuntu update problem forum, however I cannot seem to find anything that works. I cannot seem to figure out how to fix the issue where it keeps saying the packages or files with Zesty are unable to be found. Below I have copied the code I get when I type in sudo apt-get update.
Ign:1 http://archive.ubuntu.com/ubuntu zesty InRelease
Hit:2 http://ppa.launchpad.net/fenics-packages/fenics/ubuntu zesty InRelease
Ign:3 http://archive.ubuntu.com/ubuntu zesty-updates InRelease
Ign:4 http://archive.ubuntu.com/ubuntu zesty-backports InRelease
Ign:5 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty InRelease
Ign:6 http://archive.ubuntu.com/ubuntu zesty-security InRelease
Err:7 http://archive.ubuntu.com/ubuntu zesty Release
  404  Not Found [IP: 91.189.88.152 80]
Ign:8 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty Release
Err:9 http://archive.ubuntu.com/ubuntu zesty-updates Release
Err:10 http://archive.ubuntu.com/ubuntu zesty-backports Release
Err:11 http://archive.ubuntu.com/ubuntu zesty-security Release
Ign:12 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main i386 Packages
Ign:13 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main all Packages
Ign:14 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main amd64 Packages
Ign:15 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main Translation-en
Ign:16 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main Translation-en_US
Ign:17 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main all DEP-11 Metadata
Ign:18 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main amd64 DEP-11 Metadata
Ign:19 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main DEP-11 64x64 Icons
Err:12 http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty/main i386 Packages
  404  Not Found
Reading package lists... Done
E: The repository 'http://archive.ubuntu.com/ubuntu zesty Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://ppa.launchpad.net/ubuntu-audio-dev/ppa/ubuntu zesty Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
E: The repository 'http://archive.ubuntu.com/ubuntu zesty-updates Release' does no longer have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu zesty-backports Release' does no longer have a Release file.
E: The repository 'http://archive.ubuntu.com/ubuntu zesty-security Release' does no longer have a Release file.
Chai T. Rex
  • 5,323
End of life for 17.04 was January 13, 2018. The repositories have been moved to a different location and must be accessed differently.
You should upgrade to 17.10 or install a long term support version like 16.04. Then you can continue with whatever you were trying to do.
Jim Knock
  • 131
