I have two root processes I want to have Desktop Icons for. One is Clam and the other is system backup. These ran fine in 17.04. The Clam one runs fine in 17.10 Wayland but the Root Backup does not although I can manually execute the command from a terminal. At login, Startup Apps is configured to run xhost si:localuser:root. Here is what the .Desktop Files look like:
[Desktop Entry]
Name=ClamTk
GenericName=Virus Scanner
Comment=Scan for threats...
Comment[en]=Scan for threats...
TryExec=clamtk
Exec=gksu "clamtk /"
Icon=clamtk
Type=Application
Terminal=false
Categories=GTK;GNOME;Utility;
StartupNotify=true
Keywords=antivirus;virus;malware;scan;scanner;
Name[en_US]=Root_ClamTk
Note the executable is Exec=gksu "clamtk /"
Here is the Backup one:
[Desktop Entry]
Version=1.1
Name=Root_Backups
Comment=Change your backup settings
Icon=org.gnome.DejaDup
Exec=gksu /usr/bin/deja-dup
StartupNotify=true
DBusActivatable=true
Type=Application
Terminal=False
Categories=Utility;Archiving;GNOME;GTK;X-GNOME-Utilities;
Keywords=déjà;deja;dup;
X-GNOME-UsesNotifications=true
Actions=backup;
Name[en_US]=Root_Backup
Again, note the executable is Exec=gksu /usr/bin/deja-dup
If I execute $gksu /usr/bin/deja-dup from a shell, it works. Running it by double clicking the Desktop icon does not. Thoughts on what I might be doing wrong?
Note: Because the 17.04 version I used had a lot of junk in it and mentioned Unity, I made a new Desktop file by copying the old one from the Applications directory just like I did in 17.04 and, like 17.04, I added the gksu manually.
Not a duplicate of the question mentioned as I AM using the xhost command. It WORKS with clamtk but not deja-dup.
Output of /var/log/syslog when I try and run root Backup .desktop
Jan 23 16:04:33 John-linux nautilus-deskto[5076]: Nautilus_menu_provider_get_background_items: assertion 'NAUTILUS_IS_MENU_PROVIDER (provider)' failed Jan 23 16:04:59
John-linux systemd[1]: Started Run anacron jobs. Jan 23 16:04:59
John-linux anacron[10403]: Anacron 2.3 started on 2018-01-23
Jan 23 16:04:59 John-linux anacron[10403]: Normal exit (0 jobs run)
jpezz
  • 1,140
