find_totalusage()
    local totalusedsize=0
    for dirname in $dirnamelist
    do
        dirsize=$(find_dir_size "$dirname")
        totalusedsize=$(( $totalusedsize + $dirsize ))
    done
    echo $totalusedsize
size=$(find_totalusage)
Any one help me find the error ?
I think the most likely explanation is that your dirsize variable is empty.
For example, in bash
$ foo=3; bar= ; echo $(( $foo + $bar ))
bash: 3 +  : syntax error: operand expected (error token is "+  ")
while in AT&T ksh
ksh:  3 +  : more tokens expected
and in BSD mksh
mksh:  3 +  : unexpected 'end of expression'
Note that all of these shells allow "bare" variable names like (( foo + bar )) in expressions, and this form may be preferable since it treats empty variables as zero values. From man bash:
   Shell variables are allowed as operands; parameter  expansion  is  per‐
   formed before the expression is evaluated.  Within an expression, shell
   variables may also be referenced by name without  using  the  parameter
   expansion  syntax.  A shell variable that is null or unset evaluates to
   0 when referenced by name without using the parameter expansion syntax.
So for example
$ foo=3; bar=7 ; echo $(( foo + bar ))
10
$ foo=3; bar= ; echo $(( foo + bar ))
steeldriver
  • 142,475
-1
man bash documents the for command as:
for name [ [ in [ word ... ] ] ; ] do list ; done
man ksh says:
for name [in word ...]; do list; done
In both cases, you need a semicolon (;) to mark the end of the expression containing the words in $dirlist.
waltinator
  • 37,856
