Possible Duplicate:
How do I change the wallpaper in LightDM?
How do i change the background of the login screen on 11.10 i have tried Simple-lightDM-Manager and now all i get is a black screen with dots and the logo
EvoandroidEvo
  • 319
  • 18
It's in the file /etc/lightdm/unity-greeter.conf. Open it with gksu gedit /etc/lightdm/unity-greeter.conf from a terminal or run dialogue. Set background= to whatever file you would like.
However make sure that file is accessible to all. It can not be in an encrypted home folder or such. The problem you have is most likely due to unity-greeter for some reason can't access the file you chose.
Zoke
  • 9,836
An easy down and dirty way is to simply replace /usr/share/backgrounds/warty-final-ubuntu.png with the image of your choice
sudo mv /usr/share/backgrounds/warty-final-ubuntu.png /usr/share/backgrounds/warty-final-ubuntu.png.bak
sudo mv new.img /usr/share/backgrounds/warty-final-ubuntu.png
sudo chmod 644 /usr/share/backgrounds/warty-final-ubuntu.png
Ideally it would be a .png, but other images work as well.
The only disadvantage (IMO) of this method is that /usr/share/backgrounds/warty-final-ubuntu.png may get updated with system upgrades.
Panther
  • 104,528
