My media player does not support 10bit hevc content, how can I convert my 10bit hevc files to 8bit?
Asked
Active
Viewed 2.2k times
This will require re-encoding with thus some loss of quality but a recent copy of FFmpeg will allow you to convert to 8bit hevc from 10bit quite easily.
I tested with the following 10bit sample:
andrew@illium~$ mediainfo --Inform="Video;%Format%:%BitDepth% bits" 10_bit.mkv
HEVC:10 bits
This sample was re-encoded as follows:
ffmpeg -i 10_bit.mkv \
-c:v libx265 -preset medium -x265-params crf=28 -pix_fmt yuv420p \
-c:a copy \
8_bit.mkv
The crucial option here is: -pix_fmt yuv420p. The output file demonstrated a successful conversion to 8bit:
andrew@illium~$ mediainfo --Inform="Video;%Format%:%BitDepth% bits" 8_bit.mkv
HEVC:8 bits
If you can try and avoid re-encoding in this manner though, better to encode from the original media file thus avoiding some degradation of the image and loss of quality...
References:
- Set bit depth in FFmpeg encoding for HEVC? Some more details about setting the bit depth for hevc...
andrew.46
- 39,359
