When I'm trying update ubuntu packages using command sudo apt-get -f install I'm getting below error -
The following additional packages will be installed:
kde-config-telepathy-accounts
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 602 not upgraded.
751 not fully installed or removed.
Need to get 0 B/137 kB of archives.
After this operation, 825 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 274324 files and directories currently installed.)
Preparing to unpack .../kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb ...
Unpacking kde-config-telepathy-accounts (4:15.12.3-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/kde-config-telepathy-accounts_4%3a15.12.3-0ubuntu1_amd64.deb (--unpack):
trying to overwrite '/usr/share/accounts/services/google-im.service', which is also in package account-plugin-google 0.12+16.04.20160126-0ubuntu1
Processing triggers for libc-bin (2.23-0ubuntu3) ...
I use Ubuntu 16.04.
Please let me know if you need more details.
