I am trying to connect my desktop running Ubuntu 16.04 to a Raspberry Pi3 running Ubuntu MATE. The end goal is to ssh using Ethernet connection by assigning static IP addresses to PC (say 10.0.0.1) and to Pi (say 10.0.0.2).
Then I can do ssh pi@10.0.0.2 from the PC, right?. I have connected PC and Pi using ethernet/lan cable. Then I disabled Enable Wi-Fi option on Raspberry Pi and I can see that it is connected to Wired Connection 1. Running ifconfig command on the Raspberry Pi gives:
pi@pi-desktop:~$ ifconfig
enxb827eb3d64cc Link encap:Ethernet HWaddr b8:27:eb:3d:64:cc
inet addr:192.168.100.1 Bcast:192.168.100.255 Mask:255.255.255.0
inet6 addr: fe80::afe3:308f:92f3:e890/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:662 errors:0 dropped:0 overruns:0 frame:0
TX packets:111 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:151040 (151.0 KB) TX bytes:19190 (19.1 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:21628 errors:0 dropped:0 overruns:0 frame:0
TX packets:21628 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1300280 (1.3 MB) TX bytes:1300280 (1.3 MB)
Then I was planning to set PCs IP address to 192.168.100.2 but it is not connected to Wired Connection 1 even with Enable Wi-Fi disabled. Running ifconfig on PC gives:
pc@pc-desk:~$ ifconfig
enp3s0 Link encap:Ethernet HWaddr 74:d4:35:d1:2c:f4
inet6 addr: fe80::181f:fbbb:63d2:c4e4/64 Scope:Link
RX packets:106 errors:0 dropped:0 overruns:0 frame:0
TX packets:1386 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:17736 (17.7 KB) TX bytes:263114 (263.1 KB)
RX packets:9695 errors:0 dropped:0 overruns:0 frame:0
TX packets:9695 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:845799 (845.7 KB) TX bytes:845799 (845.7 KB)
I am stuck here. Any pointers would be highly appreciated.
Edit: Output of ethtool
On PC:
pc@pc-desk:~$ ethtool enp3s0
Settings for enp3s0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric Receive-only
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: internal
Auto-negotiation: on
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00000033 (51)
drv probe ifdown ifup
Link detected: yes
On Raspberry Pi :
pi@pi-desktop:~$ ethtool enxb827eb3d64cc
Settings for enxb827eb3d64cc:
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
Output of uname -a command:
On Raspberry Pi:
pi@pi-desktop:~$ uname -a
Linux pi-desktop 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l armv7l armv7l GNU/Linux
On PC:
pc@pc-desk:~$ uname -a
Linux pc-desk 4.13.0-26-generic #29~16.04.2-Ubuntu SMP Tue Jan 9 22:00:44 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
