Attempting to install steam and optimized drivers from Oibaf PPA, I was faced with a loop at login, where entering my credentials would briefly display a command-line and then return the login screen with fields emptied.
Muckee
  • 103
Using Ctrl + Alt + F4, I was able to access the CLI and discovered errors similar to those found within this question.
I deleted the Oibaf entries from /etc/apt/sources.list.d.
This had no effect. As this was not the only repository I had newly been working from, I added the repository again to maintain continuity in troubleshooting.
Following luke's solution here I still had the same issue.
I was able to login to the desktop again after running the following command:
sudo apt -f upgrade
Note:
For some implementations of the amd drivers, they can be reverted by entering
amdgpu-pro-uninstall
pomsky
  • 70,557
Muckee
  • 103
