I recently asked this question. You might read it to see what problems I'm experimenting, but it's not needed.
The thing is, I booted my computer from a live session of GParted, and I'm able to see both of my partitions, sda1, and sda2, which contain important data I'd like to save.
Since I can see this data from the live session, I connected another USB to my laptop, I mounted this USB, and passed around 5Gb of this important data to the newly inserted USB. I thought that this would save the data, and that then I would be able to wipe the disk and reinstall Ubuntu, but sadly, when I insert the USB with the important data to my Windows computer, I'm not able to open the data, I see the following picture.
I think that this is because of using different file systems, but I'm not sure, since this problem doesn't happen when using a normal Ubuntu instead of a live session of GParted.
When I try to manipulate the data from the live session, I can do it without any problems.
The problem here is that I can't wipe the disk if I don't know if the data copied to the USB will be accessible from the new Ubuntu, and I don't have any other Ubuntu machine to check if the data is correctly accessible.
Is my assumption right? Will I be able to see and use the files in the USB if I wipe the disk and install Ubuntu from zero? What other method can I use to save these files?
Please note that I can't open a live session of Ubuntu, only one of GParted.
your problem is that gparted doesn't copy files, it copies partitons -- raw data sector by sector.
Thus if you are going to copy data from an ext partition and paste it into an ntfs partition, you will end up with a bunch or garbage since the two file systems are radically different.
You need to copy to idendical file systems or use cloning software, such as clonezilla.
ravery
  • 6,924
