When running sudo apt-get update -q, sometimes I see things like
Err:23 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu precise/main i386 Packages
  Could not connect to ppa.launchpad.net:80 (91.189.95.83), connection timed out
Err:24 http://ppa.launchpad.net/chris-lea/redis-server/ubuntu precise/main Translation-en
  Unable to connect to ppa.launchpad.net:http:
or like
W: http://us-central1.gce.archive.ubuntu.com/ubuntu/dists/precise-updates/InRelease: Signature by key 630239CC130E1A7FD81A27B140976EAF437D05B5 uses weak digest algorithm (SHA1)
But echo $? tells me that apt-get update -q succeeded. How can I get the error/warning status to be fatal, and make apt-get update fail with a non-zero exit code?
Jason Gross
  • 105
You could create a bash script that check the command output :
if { apt-get update 2>&1 || echo E: update failed; } > result.txt; cat result.txt | grep -q '^[(W)|(E]:'; then
    echo error
else (
        if  cat result.txt | grep -q '^[(Get)]:'; then
            echo repaired
        else
            echo success
        fi
fi
Here, we check if a line start with E (Err: or E:, etc..) for errors or with W for warnings. Both return the status code error.
If there is no error and there is a Get:, it means that we update our repos. It returns the status code repaired.
And finally, if we havent encountered any of those, the script was a success.
As mentioned by @Terrance, this question is very close to that other question apt-get update exit status (in Unix & Linux StackExchange).
FYI I've just posted there another solution that can also be combined with the travis_retry Travis CI command (which might be the intended use case of the OP):
exec {fd}>&2 # copy stderr to some unused fd
travis_retry bash -o pipefail -c "sudo apt-get update -y -q 2>&1 | tee /dev/fd/$fd | ( ! grep -q -e '^Err:' -e '^E:' )"
exec {fd}>&- # close file descriptor
ErikMD
  • 124
