I have a Broadcom 43142 combination wifi+bluetooth network adapter, and I'm trying to get it to play nice with Ubuntu 16.04. I am new to Linux, so struggling to understand some of the possible solutions on the internet. One resource that I have found indicates that I need to install the correct firmware from a list that they supply. In the ReadMe page for that github repository includes some terminal output where you can find out what firmware is required, but it doesn't say what command is used to achieve that output. The example output is as follows:
Bluetooth: hci1: BCM: chip id 63
Bluetooth: hci1: BCM20702A
Bluetooth: hci1: BCM20702A1 (001.002.014) build 0000
bluetooth hci1: Direct firmware load for brcm/BCM20702A1-0b05-17cb.hcd failed with error -2
Bluetooth: hci1: BCM: Patch brcm/BCM20702A1-0b05-17cb.hcd not found
From this, one can determine that the required firmware is brcm/BCM20702A1-0b05-17cb.hcd.
How can I find this information on my own system?
Thanks in advance.
More info: Some people may ask to see the output of some terminal commands. Here is what I have so far:
lspci:
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.3 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3)
00:1c.4 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #5 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
06:00.0 Network controller: Broadcom Corporation BCM43142 802.11b/g/n (rev 01)
07:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller (rev 07)
08:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)\
lsusb:
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 0a5c:21d7 Broadcom Corp. BCM43142 Bluetooth 4.0
Bus 001 Device 003: ID 0c45:6a04 Microdia
Bus 001 Device 002: ID 8087:8001 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sudo service bluetooth status:
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2018-01-15 19:42:53 SAST; 1h 39min ago
Docs: man:bluetoothd(8)
Main PID: 1027 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─1027 /usr/lib/bluetooth/bluetoothd
Jan 15 19:42:53 Matt-Laptop bluetoothd[1027]: Not enough free handles to register service
Jan 15 19:42:53 Matt-Laptop bluetoothd[1027]: Sap driver initialization failed.
Jan 15 19:42:53 Matt-Laptop bluetoothd[1027]: sap-server: Operation not permitted (1)
Jan 15 19:43:03 Matt-Laptop bluetoothd[1027]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSource
Jan 15 19:43:03 Matt-Laptop bluetoothd[1027]: Endpoint registered: sender=:1.47 path=/MediaEndpoint/A2DPSink
Jan 15 19:43:52 Matt-Laptop bluetoothd[1027]: Endpoint registered: sender=:1.74 path=/MediaEndpoint/A2DPSource
Jan 15 19:43:52 Matt-Laptop bluetoothd[1027]: Endpoint registered: sender=:1.74 path=/MediaEndpoint/A2DPSink
Jan 15 19:43:52 Matt-Laptop bluetoothd[1027]: RFCOMM server failed for Headset Voice gateway: rfcomm_bind: Address already in use (98)
Jan 15 19:44:08 Matt-Laptop bluetoothd[1027]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSource
Jan 15 19:44:08 Matt-Laptop bluetoothd[1027]: Endpoint unregistered: sender=:1.47 path=/MediaEndpoint/A2DPSink
rfkill list:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
