I'm new to Ubuntu. I recently bought a PL2303 USB to Serial connector and had placed its driver PL2303.C to my Ubuntu 17.10.
I put the command 'lsusb', and it showed:
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 004: ID 8087:07dc Intel Corp.
Bus 002 Device 003: ID 1bcf:28b4 Sunplus Innovation Technology Inc.
Bus 002 Device 002: ID 138a:0011 Validity Sensors, Inc. VFS5011 Fingerprint Reader
**Bus 002 Device 005: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port**
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
and when I checked the 'dmesg' command ==> dmesg | grep tty it shows:
[    0.000000] console [tty0] enabled
[   19.113237] usb 2-3: pl2303 converter now attached to ttyUSB0
[   25.449300] ttyS3: LSR safety check engaged!
[   25.449943] ttyS3: LSR safety check engaged!
But when I plug that serial to the console port of my switch (i used the original dongle, so dongle must be not an issue), it won't appear. I suspect the com port. but i already check it with the command ==> setserial -g /dev/ttyS[0123456789], it shows :
/dev/ttyS0, UART: unknown, Port: 0x03f8, IRQ: 4
/dev/ttyS1, UART: unknown, Port: 0x02f8, IRQ: 3
/dev/ttyS2, UART: unknown, Port: 0x03e8, IRQ: 4
/dev/ttyS3: No such device
/dev/ttyS4, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS5, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS6, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS7, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS8, UART: unknown, Port: 0x0000, IRQ: 0
/dev/ttyS9, UART: unknown, Port: 0x0000, IRQ: 0
how to set com port (/dev/ttyS0) in order to be able to connected to the switch? PLease advise
To use putty in Ubuntu 17.10, you need to launch Ubuntu in XOrg. Follow the following answer to launch XOrg: How do you switch from Wayland back to Xorg in Ubuntu 17.10?
Your USB Serial device is at /dev/ttyUSB0. Make sure that you are using that for your putty connection.
sudo putty /dev/ttyUSB0 -serial -sercfg 9600,8,n,1,N
Make sure that you set the speed correctly for the console connection to the switch. It might be 115200 or 19200 or 9600.
Hope this helps!
Terrance
  • 43,712
