What is the easiest way to make it so that the only way anyone could access the ssh or ftp for my ubuntu machine is to be on a certain ip address?
Asked
Active
Viewed 3.3k times
13
Ubuntu Firewall (ufw).
See if Ubuntu Firewall is active:
$ sudo ufw status
If it's inactive, enable it:
$ sudo ufw enable
Allow SSH connections from a specific IP address:
$ sudo ufw allow from 123.123.123.123 to any port 22 proto tcp
Allow FTP connections
$ sudo ufw allow from 123.123.123.123 to any port 21 proto tcp
View firewall rules:
$ sudo ufw status
Delete above SSH rule:
$ sudo ufw delete allow from 123.123.123.123 to any port 22 proto tcp
Disable Ubuntu Firewall:
$ sudo ufw disable
Vanessa Deagan
- 1,139
The easiest way is using the firewall. DigitalOcean has a great tutorial on configuring ufw.
First make sure ufw is enabled, if not enable it:
sudo ufw status
sudo ufw enable
The relevant command for ssh/ftp from one address would be
sudo ufw allow from 15.15.15.15 to any port 22
sudo ufw allow from 15.15.15.15 to any port 21
Port 22 is the defaut for SSH, 21 is the default for FTP. You can replace 15.15.15.15 by either a subnet you want or a specific IP.
Pabi
- 7,429
