I am experienced the following issue: after hibernation (using command sudo systemctl hibernatein a terminal or the menu on the right top of Ubuntu desktop) I get a black screen (Even though all devices seem to work. The fan works!) and I am forced to reboot the OS because resume failed and I can't back to a "saved state".
The content in etc/polkit-1/localauthority/50-local.d/com.ubuntu.enable-hibernate.pkla is:
[Re-enable hibernate by default in upower]
Identity=unix-user:*
Action=org.freedesktop.upower.hibernate
ResultActive=yes
[Re-enable hibernate by default in logind]
Action=org.freedesktop.login1.hibernate;org.freedesktop.login1.handle-hibernate-key;org.freedesktop.login1;org.freedesktop.login1.hibernate-multiple-sessions;org.freedesktop.login1.hibernate-ignore-inhibit
ResultActive=yes
Additional info: Ubuntu version: 16.04LTS
Kernel version:
uname -r
4.13.0-26-generic
Graphic info:
udo lspci | grep -E 'VGA|Display'
[sudo] password di michele:
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Whistler [Radeon HD 6730M/6770M/7690M XT] (rev ff)
michele@michele-ubuntu:~$ sudo lshw -c display | grep driver
configuration: driver=i915 latency=0
CPU info:
sudo lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 2
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 42
Model name: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
Stepping: 7
CPU MHz: 1995.561
CPU max MHz: 2900,0000
CPU min MHz: 800,0000
BogoMIPS: 3991.12
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 6144K
NUMA node0 CPU(s): 0-7
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx lahf_lm epb pti tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm ida arat pln pts
Why does the resuming fail? Thanks in advance for your help.
