Just to clarify: I've look up to each existing question with accepted answers, but these questions were asked before Ubuntu 16.04 LTS came out and these answers are no longer working. Tried everything from said commands, but I still can't run 32bit applications.
I'm using Ubuntu 16.04 LTS 64bit. All said libraries are installed, but I still can't get the 32bit applicaton work. This is terminal dump:
error while loading shared libraries: libX11.so.6: cannot open shared object file: No such file or directory
Google doesn't help much and as I said, each question that already have an accepted answer just has outdated informations that are no longer supported or I don't know why it doesn't work, it just doesn't. I've got a little bit upset and will accept ANY working answer.
Polda18
  • 111
Okay, thanks to @muru's answer linked me to related question's answer, I've managed to get my 32bit application working on Ubuntu 64bit.
What I needed was dpkg -S missing-lib-file.so command to find out package containing the missing library, and apt-get install package-name:i386 command to install 32bit compatible package containing the missing library.
Thread can be closed.
Polda18
  • 111
