Before recently discovering about zathura I have been using evince.
I have a script to build and open my resume and want to open it with zathura. How can I force zathura to only open it once?
The command I am using in my script is zathura file.pdf & but this opens a new instance every time the script is run?
user10853
  • 1,626
When using SyncTeX with zathura, it does this automatically:
zathura --synctex-forward 10:1:main.tex main.pdf
searches for zathura instances looking at main.pdf and sends them the command to look at the output of line 10, column 1 in main.tex. If no instance is open, it opens a new one. All subsequent calls then just focus the already open one.
When there is no synctex file for the pdf, it works fine. But if there is a corresponding synctex file and you enter an invalid address, zathura complains in standard output, so the command that I am using for viewing (without synctex) is
zathura --synctex-forward :: main.pdf > /dev/null &
where the :: is so that zathura can parse the synctex command and > /dev/null is to silence the output
Maybe there is another option than hijacking the SyncTeX functionality.
In that case your script could work by killing all zathura instances before open it again:
killall zathura #Kill all previous zathura instances zathura file.pdf & #Open zathura
Hope it helps.
galoget
  • 3,023
You can write a script to launch the same window if a file is already opened in zathura.
Save script below to your local drive. For example ~/unique_zathura_launcher.sh. Now, you open your file with ~/unique_zathura_launcher.sh filename.pdf instead of zathura filename.pdf. You can create an alias to save keystrokes.
You can use this script as the default application for pdf files. Simply right click a pdf file and choose 'open with command' and add ~/unique_zathura_launcher.sh as the command. As a result, you will no longer open the same file in multiple zathura instances.
What the script below does is simply check if any zathrua process contains the input file path. If yes, find the window id and activate it. Otherwise, launch a new zathura instance.
#!/bin/bash
This script assumes all files are passed with an absolute path. Otherwise, it may not work properly.
inputAbsPath=$(realpath -s $1) inputBasename=$(basename "$1") zathuraProcess=$(ps aux | grep zathura | grep -v grep)
if [[ -z $zathuraProcess ]] then # open the file directly if no zathura process is detected zathura "$1" & exit fi
pdfProcessWindowId="undefined"
while read -r pdfProcess; do pdfProcessPid=$(echo $pdfProcess | awk '{print $2}') if [[ -n $(wmctrl -l -p | grep $pdfProcessPid | grep -v grep) ]] && [[ -n $(wmctrl -l -p | grep $pdfProcessPid | grep -v grep | awk '{print $1}') ]] then pdfProcessWindowId=$(wmctrl -l -p | grep $pdfProcessPid | grep -v grep | awk '{print $1}' | head -n 1) fi done <<< "$(ps aux | grep zathura | grep "$inputAbsPath" | grep -v grep)"
if [[ $pdfProcessWindowId == "undefined" ]] then zathura "$1" & else wmctrl -ia $pdfProcessWindowId fi
Hank
