I recently upgraded to 17.10 from 16.10, and I'm experiencing an annoying problem:
I CAN'T drag and drop files. When I select files and then hold to drag, it behaves as though I'm re-selecting and doesn't drag the files like it did in 16.10.
Also, ctrl- and shift- selecting no longer work the way they used to, shift now selects from the FIRST file selected rather than the LAST file I selected.
I don't know if these are OS bugs or if there's an easy solution.
PLEASE HELP. I don't want to have to re-install 16.10
open terminal
    gsettings set org.gnome.nautilus.preferences use-experimental-views false
It seems it's a bug with Wayland.
As a workaround you may switch back to Xorg following this Q&A: How do you switch from Wayland back to Xorg in Ubuntu 17.10?
pomsky
  • 70,557
