right now I have multiple instructions that I have to add separately by manual labor (start terminal, copy paste instructions, insert instructions into text file), so I thought there must be a way to pack all of these commands into a single text file and have it run once.
For example I need to do 2 configurations:
1st Configuration
  1. create file with:
    sudo nano /usr/local/bin/loadFlysoftPOS
  2. copy following text into the above text file:
    #/bin/bash until pids=$(pidof mysqld)
    do
    sleep 1
    done
    cd ~/Dokumente/dist/
    java -jar POSv2.jar > log.txt
  3. make it runnable by current user
    sudo chmod +x /usr/local/bin/loadFlysoftPOS
2nd Configuration
  1. create file:
    sudo nano /etc/udev/rules.d/10-local.rules
  2. insert text into file:
    SUBSYSTEMS=="usb", DRIVERS=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="a700", SYMLINK+="usb/sewoo1", GROUP="lp"
So is it possible to store all those instructions into a single script and have it run once? Also importantly is to override any existing file, so if there already is a file called /etc/udev/rules.d/10-local.rules, its content should be cleared and overwritten by the contents provided by the new script.
Thanks guys for the enlightment!
Chiggiddi
  • 345
nano is an interactive text editor - IMHO it isn't helpful for creating file content programatically.
For your first case, I'd suggest using a here document:
cat << \EOF > /usr/local/bin/loadFlysoftPOS
#!/bin/bash
until $(pidof mysqld)
do
  sleep 1
done
cd $HOME/Dokumente/dist/ && java -jar POSv2.jar > log.txt
EOF
For the second case, a simple echo should do:
echo 'SUBSYSTEMS=="usb", DRIVERS=="usb", ATTRS{idVendor}=="0525", ATTRS{idProduct}=="a700", SYMLINK+="usb/sewoo1", GROUP="lp"' > /etc/udev/rules.d/10-local.rules
Put the whole thing in a file with its own shebang:
File: myscript.sh
#!/bin/sh
#!/bin/bash
do
  sleep 1
done
EOF
Make it executable, and run it with sudo
chmod +x myscript.sh
sudo ./myscript.sh
steeldriver
  • 142,475
