I have been to the website & while there is talk of it being compatible there is no actual Linux supported link for it, its all exe's. I am using Ubuntu Mate the latest version 64Bit edition.
If someone can provide a direct link or terminal code to make it happen because its not showing up under the software center even with 3rd party enabled.
AWFordJr
  • 121
Rufus app is available for Windows platform only.
But you can use other softwares like winusb, dd, unetbootin, ....
Here is short dd tutorial for making bootable drives :
Plug in the USB flash drive and determine the device it's mounted on with the command:
sudo fdisk -l
This time around it was /dev/sdc1 for me, so I'll use that as my example.
Unmount the device
umount /dev/sdc1
The next step is to copy the iso. Copy to the device not partition (i.e copy to sdc not sdc1) as shown below:
sudo dd if=filename.iso of=/dev/sdc bs=4M
Perform final steps :
sync
sudo eject /dev/sdc
That's all . :)
Source
Olimjon
  • 7,522
