I've installed and used Wine countless times over the years but after a fresh install of Ubuntu 17.10 onto a new PC, Wine seems to install but nothing can be found. It is not in the menu and I can't locate anywhere in the menu settings to enable it. Also, I installed a Windows application but it too has disappeared. No desktop icon and nothing in the menu. Reading whatever I could find here and elsewhere I found nothing that solved the problem! I did install from the command line using the details found on the winehq site and entering winecfg does bring up the settings box.
I was told I needed to install winetricks which I did but still nothing but winetricks in the menu. When trying to install a Windows application and choosing Properties->Open With Wine is not an option but running winecfg brings it up so it is clearly running.
I wonder if it's a clue as winecfg outputs many errors even though it does load the interface.
$ winecfg
wine: created the configuration directory '/home/don/.wine'
err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
err:ole:marshal_object couldn't get IPSFactory buffer for interface {6d5140c1-7436-11ce-8034-00aa006009fa}
err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80004002
err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, 80004002
err:ole:get_local_server_stream Failed: 80004002
err:mscoree:LoadLibraryShim error reading registry key for$ winecfg
err:mscoree:LoadLibraryShim error reading registry key for installroot
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
wine: configuration in '/home/don/.wine' has been updated. installroot
Byte Commander
  • 110,243
DonP
  • 492
The solution was to install a different desktop! Apparently the default that comes with Ubuntu Studio 17.10 does odd things and the one now also better supports my desktop PC's touchscreen display.
DonP
  • 492
