Sorry for the duplicate question but I have read these links:
But none of above links solved my problem.
Actually, the question is same, but the meaning is different. I want to change disk boot order on my computer (which disk will boot first, second and third. like CD-ROM -> Hard-Disk -> USB- Drive). I can do it using BIOS settings, but I want to change disk boot order using Ubuntu.
When I type sudo fdisk -l on the terminal, I get the following result.
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: E7225B99-3850-4E61-8D35-D3D269A42F1A
Device Start End Sectors Size Type
/dev/sda1 2048 421529599 421527552 201G Microsoft basic data
/dev/sda2 421529600 840959999 419430400 200G Microsoft basic data
/dev/sda3 840960000 841881599 921600 450M Windows recovery environment
/dev/sda4 841881600 842086399 204800 100M EFI System
/dev/sda5 842086400 842119167 32768 16M Microsoft reserved
/dev/sda6 843057152 864028671 20971520 10G Microsoft basic data
/dev/sda7 864028672 1015023615 150994944 72G Linux filesystem
/dev/sda8 1015023616 1224738815 209715200 100G Microsoft basic data
/dev/sda9 1226835968 1436551167 209715200 100G Microsoft basic data
/dev/sda10 1438648320 1635380309 196731990 93.8G Microsoft basic data
/dev/sda11 1635381248 1710135295 74754048 35.7G Linux filesystem
/dev/sda12 1710135296 1953523711 243388416 116.1G Linux filesystem
Disk /dev/sdb: 14.9 GiB, 16005464064 bytes, 31260672 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x05fec185
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 31260671 31258624 14.9G c W95 FAT32 (LBA)
Here, currently, I have two disks One internal HDD (1 TB) and second external USB Drive (14.9 GB).
Is there any command in Linux?
