Following official instructions from here: https://developer.nvidia.com/cuda-80-ga2-download-archive.
michael@Pascal:~/temp$ ll
total 1.8G
-rw-r--r-- 1 root 1.8G Feb 1 2017 cuda-repo-ubuntu1604-8-0-local-ga2_8.0.61-1_amd64.deb
michael@Pascal:~/temp$ sudo dpkg -i cuda-repo-ubuntu1604-8-0-local-ga2_8.0.61-1_amd64.deb
(Reading database ... 92745 files and directories currently installed.)
Preparing to unpack cuda-repo-ubuntu1604-8-0-local-ga2_8.0.61-1_amd64.deb ...
Unpacking cuda-repo-ubuntu1604-8-0-local-ga2 (8.0.61-1) over (8.0.61-1) ...
Setting up cuda-repo-ubuntu1604-8-0-local-ga2 (8.0.61-1) ...
OK
michael@Pascal:~/temp$ sudo apt-get update
Hit:1 http://archive.canonical.com/ubuntu xenial InRelease
Hit:2 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [102 kB]
Hit:4 http://security.ubuntu.com/ubuntu xenial-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu xenial InRelease
Hit:6 http://archive.ubuntu.com/ubuntu xenial-updates InRelease
Get:7 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [102 kB]
Hit:8 http://archive.ubuntu.com/ubuntu xenial-backports InRelease
Hit:9 http://archive.ubuntu.com/ubuntu xenial-security InRelease
Fetched 204 kB in 0s (267 kB/s)
Reading package lists... Done
michael@Pascal:~/temp$ sudo apt-get install cuda
Building dependency tree
E: Unable to locate package cuda
I tried manually copying the .deb file to /var/cuda-repo-8-0-local-ga2 but got the same error.
That 1.8GB .deb file I downloaded is sitting right there, why can't it see it? CUDA is not installed: sudo apt-get remove --purge nvidia-* shows "0 to remove"
Nothing from Nvidia has been installed:
$ nvcc -V
The program 'nvcc' is currently not installed. You can install it by typing:
sudo apt install nvidia-cuda-toolkit` and `nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
The step that actually installs CUDA is sudo apt-get install cuda, and that didn't go through, as you can see from my post.
$ dpkg-query -s cuda
dpkg-query: package 'cuda' is not installed and no information is available
