I ran sudo snap install anbox-installer --classic
Then ran anbox-installer in the terminal.
-------- Uninstall Beginning --------
Module: anbox-modules-ashmem
Version: 9~xenial1
Kernel: 4.10.0-42-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
ashmem_linux.ko:
- Uninstallation
- Deleting from: /lib/modules/4.10.0-42-generic/updates/dkms/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
depmod....
DKMS: uninstall completed.
Version: 9~xenial1
Kernel: 4.4.0-109-generic (x86_64)
ashmem_linux.ko:
- Uninstallation
- Deleting from: /lib/modules/4.4.0-109-generic/updates/dkms/
- Original module
depmod....
Deleting module version: 9~xenial1
completely from the DKMS tree.
Done.
Loading new anbox-modules-ashmem-9~xenial1 DKMS files...
First Installation: checking all kernels...
Building only for 4.10.0-42-generic
Building for architecture x86_64
Building initial module for 4.10.0-42-generic
Done.
ashmem_linux:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.10.0-42-generic/updates/dkms/
depmod....
DKMS: install completed.
Removing old anbox-modules-binder-9~xenial1 DKMS files...
Module: anbox-modules-binder
Version: 9~xenial1
binder_linux.ko:
- Uninstallation
- Original module
depmod....
Version: 9~xenial1
binder_linux.ko:
- Uninstallation
- Original module
depmod....
Done.
Loading new anbox-modules-binder-9~xenial1 DKMS files...
Done.
binder_linux:
- Original module
- Installation
depmod....
Processing triggers for shim-signed (1.32~16.04.1+0.9+1474479173.6c180c6-1ubuntu1) ...
+ sudo modprobe binder_linux
modprobe: ERROR: could not insert 'binder_linux': Required key not available
+ cleanup
+ local err=1
+ trap - EXIT
+ echo 'ERROR: Installation failed. Removing all parts of Anbox again.'
+ uninstall
+ set -x
+ sudo snap remove anbox
snap "anbox" is not installed
+ '[' -e /etc/apt/sources.list.d/morphis-ubuntu-anbox-support-xenial.list ']'
+ ppa_purged_installed=0
+ grep -q ppa-purge
+ dpkg --get-selections
+ sudo apt install -y ppa-purge
Reading package lists... Done
Building dependency tree
I am receiving these errors. What should i do ?
